Einleitung
This guide shows you how to Replace a Filter on Whirlpool W10407342B side-by-side refrigerator.
Replacing your filter every six months is good both for the cleanliness of your refrigerator as well as your health.
Changing the filter is quick and easy. Make sure you buy a genuine Whirlpool water filter, as there are some DRM locks on third party filters.
Was du brauchst
Place a towel under the water filter cover door at the base grille.
Remove the new filter from its packaging and take the coverings off the O-rings.
Point the arrow on the filter toward the left and slide it into the filter hole.
Push the filter indicator switch five times to reset the filter indicator to green.
Using a sturdy container to catch the water, depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds.
Repeat until water begins to flow.
Once the water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on and 5 seconds off) until a total of 3 gallons had been dispensed.
You have successfully replaced the water filter on your Whirlpool W10407342B side-by-side refrigerator!
Eine weitere Person hat diese Anleitung absolviert.
