Einleitung
Use this guide to help replace the battery of your Guess W0016L2 watch. This guide can also be used for other watches with a screw-on case.
No special skills or knowledge are required to complete this process.
Watch batteries tend to die over time, causing your watch to stop working. If you find that your watch has stopped, replace the battery to get it running again.
Was du brauchst
Press the buttons on the sides of the watch clasp to release the latch.
Open the watch clasp.
Place the watch on its side.
Use a pin tool to push the clasp pin out from the side and remove it.
Align the tip of the huaxing tool with the notches on the back case of the watch.
Once the huaxing tool is aligned with the notches on the back of the watch, turn it counterclockwise to unscrew the back case.
Use a spudger to gently lift the battery clip just enough to slide the battery out from the holder.
Use tweezers or your hands to place the new battery into the battery slot with the positive side facing upwards.
Set the plastic guard back in place by aligning it with the stems of the crown.
Replace the back case of the watch.
Align the watch case opener with the notches on the back case and turn it clockwise to tighten.
Insert the pin into the watch link.
Slide the pin into one of the holes of the clasp.
Push the pin down and place it under the second hole of the clasp.
Eine weitere Person hat diese Anleitung absolviert.
