Zum Hauptinhalt wechseln
How to Replace a Honda CRV 2007-2013 Key Fob Battery
Was du brauchst
  1. How to Replace a Honda CRV 2007-2013 Key Fob Battery, Key Fob Battery: Schritt 1, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery, Key Fob Battery: Schritt 1, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery, Key Fob Battery: Schritt 1, Bild 3 von 3
    • Flip the key fob on the side with the Honda logo.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw.
  2. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 2, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 2, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 2, Bild 3 von 3
    • Use an opening tool to pry the shell of the key fob starting from the notch on the bottom left corner.
    • Work your way around the bottom side of the shell but don't pry the top side of the shell yet.
    • Don't use excessive force when prying. The top side of the shell is not supposed to be pried yet.
  3. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 3, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 3, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 3, Bild 3 von 3
    • Use minimal force to lift the shell and separate the two parts.
    • Exercise caution when applying force, as the case is connected by a plastic hinge that could break easily.
  4. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 4, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 4, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 4, Bild 3 von 3
    • Pull out the internal component of the key fob.
  5. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 5, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 5, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 5, Bild 3 von 3
    • Use the notch on the top right to separate the two halves of the component.
  6. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 6, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 6, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 6, Bild 3 von 3
    • Use a plastic spudger to pry the battery out of the socket.
  7. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 7, Bild 1 von 1
    • Replace the old battery with a CR 1616 battery.
    • Make sure that the positive side of the battery is on the bottom.
  8. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 8, Bild 1 von 2 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 8, Bild 2 von 2
    • Securely connect both parts of the internal component together.
  9. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 9, Bild 1 von 2 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 9, Bild 2 von 2
    • Place the internal component back into the bottom part of the shell.
  10. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 10, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 10, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 10, Bild 3 von 3
    • Align both halves of the fob shell precisely.
    • Join the two halves of the shell together starting from the top of the fob and work your way to the bottom.
  11. How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 11, Bild 1 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 11, Bild 2 von 3 How to Replace a Honda CRV 2007-2013 Key Fob Battery: Schritt 11, Bild 3 von 3
    • Use a Phillips #00 screwdriver to replace the single screw.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
David
193 Reputation
1 Anleitung geschrieben
York University, Team C-31, O'Regan Fall 2023 Mitglied von York University, Team C-31, O'Regan Fall 2023
YORK-O'REGAN-F23SCG31
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 35
Letzte 7 Tage: 157
Letzte 30 Tage: 630
Insgesamt: 2,312
