Zum Hauptinhalt wechseln
How to Replace a Hoodie Drawstring
Was du brauchst
  1. How to Replace a Hoodie Drawstring, Hoodie Drawstring: Schritt 1, Bild 1 von 2 How to Replace a Hoodie Drawstring, Hoodie Drawstring: Schritt 1, Bild 2 von 2
    • If the broken or old drawstring is still in the hood, gently pull it through one of the hood holes.
  2. How to Replace a Hoodie Drawstring: Schritt 2, Bild 1 von 3 How to Replace a Hoodie Drawstring: Schritt 2, Bild 2 von 3 How to Replace a Hoodie Drawstring: Schritt 2, Bild 3 von 3
    • Wrap a small piece of tape tightly around each end.
    • This step is if you have frayed edges on your drawstring.
  3. How to Replace a Hoodie Drawstring: Schritt 3, Bild 1 von 2 How to Replace a Hoodie Drawstring: Schritt 3, Bild 2 von 2
    • Open the safety pin and hook it through one end of the drawstring/shoelace.
    • If you put tape on frayed drawstring, stab the safety pin through the tape.
    • Be careful, your safety pin may be sharp!
    • Close the safety pin securely so it won't open when you put it in your hood.
  4. How to Replace a Hoodie Drawstring: Schritt 4, Bild 1 von 3 How to Replace a Hoodie Drawstring: Schritt 4, Bild 2 von 3 How to Replace a Hoodie Drawstring: Schritt 4, Bild 3 von 3
    • Insert the safety-pinned end into one drawstring hole.
    • Work it through the hood by bunching and sliding the hoodie fabric along the pin.
    • Keep feeding the pin until it exits the opposite hole.
  5. How to Replace a Hoodie Drawstring: Schritt 5, Bild 1 von 2 How to Replace a Hoodie Drawstring: Schritt 5, Bild 2 von 2
    • Pull both ends of the drawstring until they're an even length.
    • Take out your safety pin.
    • Remove you tape (if any was used).
    • Make sure your string slides freely through the hood, and confirm it tightens as it's supposed to.
  6. How to Replace a Hoodie Drawstring: Schritt 6, Bild 1 von 3 How to Replace a Hoodie Drawstring: Schritt 6, Bild 2 von 3 How to Replace a Hoodie Drawstring: Schritt 6, Bild 3 von 3
    • Tie a small knot on each end to keep the string from slipping back in your hood!
Abschluss
Replacing a hoodie drawstring is a quick, simple repair that saves your favorite hoodie from the donation pile. You can use this same method for sweatpants, jackets, or gym bags.
Eine weitere Person hat diese Anleitung absolviert.
Austin Community College, Team 98-10, Kapoor Fall 2025 Mitglied von Austin Community College, Team 98-10, Kapoor Fall 2025
AUSTINCC-KAPOOR-F25S98G10
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 65
Letzte 30 Tage: 279
Insgesamt: 791
