Zum Hauptinhalt wechseln
How to Replace a Kayak Bungee/Shock Cord
Was du brauchst
  1. How to Replace a Kayak Bungee/Shock Cord, Find the attachment points: Schritt 1, Bild 1 von 1
    • Identify the attachment points where the bungee cord is connected. These are usually eyelets, D-rings, or hooks.
  2. How to Replace a Kayak Bungee/Shock Cord, Remove the old bungee cord: Schritt 2, Bild 1 von 2 How to Replace a Kayak Bungee/Shock Cord, Remove the old bungee cord: Schritt 2, Bild 2 von 2
    • Carefully cut and pull off the old bungee cord from the attachment point using scissors or a knife.
  3. How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: Schritt 3, Bild 1 von 3 How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: Schritt 3, Bild 2 von 3 How to Replace a Kayak Bungee/Shock Cord, Measure and cut the new bungee cord: Schritt 3, Bild 3 von 3
    • Lay the new bungee cord alongside the old one.
    • Add a few extra inches to your measurement for adjustments and securing the ends.
    • Use scissors or a knife to cut the cord to the required length.
  4. How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: Schritt 4, Bild 1 von 3 How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: Schritt 4, Bild 2 von 3 How to Replace a Kayak Bungee/Shock Cord, Attach the new bungee cord: Schritt 4, Bild 3 von 3
    • Push the cord through either of the attachment points closest to the middle of the kayak.
    • You may use a pen to help guide the cord through if it doesn't go through easily on its own.
    • Tie a simple overhand knot to secure the cord on this end.
    • Thread the cord through the opposite attachment point and then to the next point on the opposite end and repeat - Creating a criss-cross pattern as you thread away from the center of the kayak.
  5. How to Replace a Kayak Bungee/Shock Cord, Test and adjust: Schritt 5, Bild 1 von 2 How to Replace a Kayak Bungee/Shock Cord, Test and adjust: Schritt 5, Bild 2 von 2
    • Gently pull on the new bungee cord to make sure it is securely attached and provides the desired tension.
    • You want the cord to be taut but not overly tight.
  6. How to Replace a Kayak Bungee/Shock Cord, Trim any excess cord: Schritt 6, Bild 1 von 2 How to Replace a Kayak Bungee/Shock Cord, Trim any excess cord: Schritt 6, Bild 2 von 2
    • Once you are satisfied with the placement and tension of the new bungee cord, tie another overhand knot to secure the bungee on this end of the kayak.
    • Finally, trim any excess length using scissors or a knife.
Abschluss
Follow these steps to remove an old bungee cord and secure a new one to your kayak.
York University, Team O-19, Woodhouse Winter 2023 Mitglied von York University, Team O-19, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG19
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 25
Letzte 30 Tage: 86
Insgesamt: 1,968
