Zum Hauptinhalt wechseln
How to Replace a Leaking Set Screw Tub Spout
Was du brauchst
  1. How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: Schritt 1, Bild 1 von 2 How to Replace a Leaking Set Screw Tub Spout, Set Screw Tub Spout: Schritt 1, Bild 2 von 2
    • Cover the shower drain with a plug or a piece of cloth to prevent the screw from falling in.
    • Make sure the water is turned off.
  2. How to Replace a Leaking Set Screw Tub Spout: Schritt 2, Bild 1 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 2, Bild 2 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 2, Bild 3 von 3
    • Using an 5/32" Allen key, loosen the screw located under the spout.
    • You should not remove the screw. But instead, untighten the screw until it's loose.
  3. How to Replace a Leaking Set Screw Tub Spout: Schritt 3, Bild 1 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 3, Bild 2 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 3, Bild 3 von 3
    • Gently pull out the spout using your hand and set it aside somewhere.
    • Protip: Wiggle the spout side to side to help pull it out.
  4. How to Replace a Leaking Set Screw Tub Spout: Schritt 4, Bild 1 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 4, Bild 2 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 4, Bild 3 von 3
    • Using sandpaper or a sponge, gently rub and clean the pipe.
    • This allows for the new set screw tub spout to easily slip on.
    • Once you have finished cleaning the pipe, wipe off the dust with a piece of cloth or paper towel.
  5. How to Replace a Leaking Set Screw Tub Spout: Schritt 5, Bild 1 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 5, Bild 2 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 5, Bild 3 von 3
    • Take your new set screw tub spout and slide it in gently into the wall.
    • Protip: Wiggle the spout side to side to help push it back in.
  6. How to Replace a Leaking Set Screw Tub Spout: Schritt 6, Bild 1 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 6, Bild 2 von 3 How to Replace a Leaking Set Screw Tub Spout: Schritt 6, Bild 3 von 3
    • Retighten the set screw using the 5/32" Allen key.
Abschluss
Turn on the bath water to ensure the set screw tub spout has no leaks and is working as intended.
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S16-G3, Turner Winter 2021 Mitglied von York University, Team S16-G3, Turner Winter 2021
YORK-TURNER-W21S16G3
3 Mitglieder
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 92
Insgesamt: 5,295
