Einleitung
Mouse scroll wheels often stop working. They can get stuck inputting one direction, or just stop working all together. If this happens to your Logitech M325c mouse scroll wheel, then you're in the right place! Here is a guide to replacing this scroll wheel.
Was du brauchst
Remove the AA battery.
Peel off the sticker at the bottom of the compartment.
Remove the single Phillips screw.
Pinch the lower case and carefully pull it to reveal the internal parts and scroll wheel.
Reattach the bottom of the mouse and fasten the single Phillips screw in the battery compartment.
