Zum Hauptinhalt wechseln
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: Schritt 1, Bild 1 von 2 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: Schritt 1, Bild 2 von 2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 2, Bild 1 von 2 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 2, Bild 2 von 2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 3, Bild 1 von 2 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 3, Bild 2 von 2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 4, Bild 1 von 3 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 4, Bild 2 von 3 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 4, Bild 3 von 3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 5, Bild 1 von 2 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 5, Bild 2 von 2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 6, Bild 1 von 2 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 6, Bild 2 von 2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 7, Bild 1 von 2 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 7, Bild 2 von 2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 8, Bild 1 von 3 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 8, Bild 2 von 3 How to Replace a Nequare Cordless Vacuum S182 Filter: Schritt 8, Bild 3 von 3
    • Put the black part back into the canister and put in the new filter.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
York University, Team S2-G27, O'Regan Winter 2021 Mitglied von York University, Team S2-G27, O'Regan Winter 2021
YORK-O'REGAN-W21S2G27
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 45
Insgesamt: 1,276
