Zum Hauptinhalt wechseln
How to Replace a Tail Light for a 2011-2015 Ford Explorer
Was du brauchst
  1. How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: Schritt 1, Bild 1 von 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer, Tail Light Bulbs: Schritt 1, Bild 2 von 2
    • Lift and open the rear cargo door.
  2. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 2, Bild 1 von 1
    • Locate the two plastic screw covers that are adjacent to the rear light covers.
  3. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 3, Bild 1 von 1
    • Using a flathead screwdriver, pry out both plastic screw covers.
  4. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 4, Bild 1 von 1
    • Once covers are removed, there will be an 8 mm hex head screw located beneath each cover.
  5. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 5, Bild 1 von 1
    • Using an 8 mm Deep Socket Wrench, remove both of the 20 mm (length) hex-head screws.
  6. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 6, Bild 1 von 2 How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 6, Bild 2 von 2
    • Gently pull the tail light cover from the car.
    • You may have to gently play with the cover by moving it back and forth in order to pry it loose form the car.
  7. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 7, Bild 1 von 1
    • Once removed, the bulb sockets will be located on the inside portion of the tail light cover.
  8. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 8, Bild 1 von 1
    • Turn the bulb socket about one quarter turn in a counterclockwise direction.
    • After it is turned, gently pull and remove the bulb socket from the tail light cover.
  9. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 9, Bild 1 von 1
    • Gently remove the bulb from the bulb socket.
  10. How to Replace a Tail Light for a 2011-2015 Ford Explorer: Schritt 10, Bild 1 von 1
    • Gently place the new bulb in the bulb socket.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 14-4, Green Fall 2015 Mitglied von Cal Poly, Team 14-4, Green Fall 2015
CPSU-GREEN-F15S14G4
5 Mitglieder
16 Anleitungen geschrieben
Ein Kommentar
That's not the tail lights that is the turn signal and back up lights.
Djay Glass - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 89
Insgesamt: 21,830
