Zum Hauptinhalt wechseln
How to Replace a Tail Light on a Nissan Pathfinder
Was du brauchst
  1. How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: Schritt 1, Bild 1 von 3 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: Schritt 1, Bild 2 von 3 How to Replace a Tail Light on a Nissan Pathfinder, Tail Light on Nissan Pathfinder: Schritt 1, Bild 3 von 3
    • Insert a flathead screwdriver into the top of the trim cover and gently pry it towards you.
    • Repeat the above step to the bottom of the trim cover.
    • Pull the trim cover off.
    • Set the trim cover aside in a safe place.
  2. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 2, Bild 1 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 2, Bild 2 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 2, Bild 3 von 3
    • Remove the two bolts using a 10mm socket and a 1/4" ratchet wrench.
    • Place the wrench on the top bolt and turn counterclockwise until the bolt is entirely off.
    • Repeat the above step to the bottom bolt.
    • Set bolts aside in a safe place.
  3. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 3, Bild 1 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 3, Bild 2 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 3, Bild 3 von 3
    • Gently pull on the tail light housing to disengage the friction fasteners from their grommets.
    • Once all fasteners have been disengaged, pull the tail light housing out.
  4. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 4, Bild 1 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 4, Bild 2 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 4, Bild 3 von 3
    • Rotate the grey plastic bulb socket 1/4 and turn counterclockwise before pulling it straight out of the housing.
    • Pull the old light bulb straight out of the socket.
  5. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 5, Bild 1 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 5, Bild 2 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 5, Bild 3 von 3
    • Push a new 7443 bulb into the socket.
    • Re-insert the socket into the housing and rotate it 1/4 turn clockwise to secure it in place.
  6. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 6, Bild 1 von 2 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 6, Bild 2 von 2
    • Line up the two metal pegs near the outer edge of the housing with their corresponding plastic grommets on the rear corner of the SUV.
    • Carefully push the tail light housing back into place.
  7. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 7, Bild 1 von 2 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 7, Bild 2 von 2
    • Spin in the two bolts a few turns by hand to prevent them from falling.
  8. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 8, Bild 1 von 2 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 8, Bild 2 von 2
    • Tighten the two bolts by turning them clockwise with the 10mm socket and a 1/4" drive ratchet until tight.
    • Avoid over-tightening the bolts to prevent from cracking the plastic inner edge of the tail light housing.
  9. How to Replace a Tail Light on a Nissan Pathfinder: Schritt 9, Bild 1 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 9, Bild 2 von 3 How to Replace a Tail Light on a Nissan Pathfinder: Schritt 9, Bild 3 von 3
    • Line up the trim cover and push it back into place over the inner edge of the tail light housing.
Abschluss
Leslie Salazar
169 Reputation
1 Anleitung geschrieben
Austin Community College, Team 22-10, Watkins Fall 2023 Mitglied von Austin Community College, Team 22-10, Watkins Fall 2023
AUSTINCC-WATKINS-F23S22G10
2 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 443
