Zum Hauptinhalt wechseln
How to Replace a Toilet's Shut-Off Valve
Was du brauchst
  1. How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: Schritt 1, Bild 1 von 2 How to Replace a Toilet's Shut-Off Valve, Shut-Off Valve: Schritt 1, Bild 2 von 2
    • Locate the water main line (typically found in your basement).
    • Turn off the water main line by rotating the knob clockwise.
  2. How to Replace a Toilet's Shut-Off Valve: Schritt 2, Bild 1 von 2 How to Replace a Toilet's Shut-Off Valve: Schritt 2, Bild 2 von 2
    • Go to the lowest level of your house and turn the faucet on at any sink.
    • Keep the faucet running until it stops spewing water. If the faucet doesn't stop, you likely turned the wrong valve in Step 1.
  3. How to Replace a Toilet's Shut-Off Valve: Schritt 3, Bild 1 von 1
    • Flush the toilet (the one that needs the valve to be replaced).
  4. How to Replace a Toilet's Shut-Off Valve: Schritt 4, Bild 1 von 2 How to Replace a Toilet's Shut-Off Valve: Schritt 4, Bild 2 von 2
    • Turn the toilet shut off valve counter clockwise.
  5. How to Replace a Toilet's Shut-Off Valve: Schritt 5, Bild 1 von 2 How to Replace a Toilet's Shut-Off Valve: Schritt 5, Bild 2 von 2
    • Using the wrench, disconnect the tank hose from the pipe by turning the wrench clockwise until the hose is completely disconnected from the pipe.
  6. How to Replace a Toilet's Shut-Off Valve: Schritt 6, Bild 1 von 2 How to Replace a Toilet's Shut-Off Valve: Schritt 6, Bild 2 von 2
    • Rotate the toilet shut-off valve clockwise with the wrench until the valve comes off from the pipe.
    • Slide the new valve onto the pipe and tighten the valve onto the pipe with the wrench.
    • Using the wrench reconnect the hose to the pipe by rotating the wrench counter clockwise.
    • Turn the water main on rotating the knob counter clockwise.
Ziellinie
Jayden Scott-Douglas
142 Reputation
1 Anleitung geschrieben
York University, Team S1-G25, O'Regan Winter 2021 Mitglied von York University, Team S1-G25, O'Regan Winter 2021
YORK-O'REGAN-W21S1G25
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 50
Insgesamt: 4,526
