Zum Hauptinhalt wechseln
How to Replace a Transition Strip (T Molding)
Was du brauchst
  1. How to Replace a Transition Strip (T Molding), Transition Strip (T Molding): Schritt 1, Bild 1 von 1
    • Measure the exact width of the doorway using a tape measure.
  2. How to Replace a Transition Strip (T Molding): Schritt 2, Bild 1 von 3 How to Replace a Transition Strip (T Molding): Schritt 2, Bild 2 von 3 How to Replace a Transition Strip (T Molding): Schritt 2, Bild 3 von 3
    • Mark the T molding based on the doorway measure.
    • Cut the T molding using a sharp saw (table saw).
    • Cutting the T molding can be done for free at the place of purchase.
    • If you don't have access to a sharp saw, cut the T molding using a jigsaw and use sanding paper to soften the end.
  3. How to Replace a Transition Strip (T Molding): Schritt 3, Bild 1 von 3 How to Replace a Transition Strip (T Molding): Schritt 3, Bild 2 von 3 How to Replace a Transition Strip (T Molding): Schritt 3, Bild 3 von 3
    • Remove the old T molding.
    • You can use a pry bar to loosen the T molding.
  4. How to Replace a Transition Strip (T Molding): Schritt 4, Bild 1 von 2 How to Replace a Transition Strip (T Molding): Schritt 4, Bild 2 von 2
    • Use a utility knife to remove all the glue or any material used to keep the old T molding in place.
    • You may use a scraper instead of a utility knife.
    • Clean up the area thoroughly.
  5. How to Replace a Transition Strip (T Molding): Schritt 5, Bild 1 von 1
    • Apply the glue evenly to the gap.
  6. How to Replace a Transition Strip (T Molding): Schritt 6, Bild 1 von 3 How to Replace a Transition Strip (T Molding): Schritt 6, Bild 2 von 3 How to Replace a Transition Strip (T Molding): Schritt 6, Bild 3 von 3
    • Insert the T molding into the gap.
    • Press the T molding firmly onto the ground.
    • No gap should exist between the T molding and the floorings.
  7. How to Replace a Transition Strip (T Molding): Schritt 7, Bild 1 von 2 How to Replace a Transition Strip (T Molding): Schritt 7, Bild 2 von 2
    • Tape the T molding onto the floor.
    • This step ensures the T molding stays in place until the glue dries.
    • Wait 24 hours for the glue to dry.
    • Remove the tapes.
Abschluss
Rojean Noorinayer
145 Reputation
1 Anleitung geschrieben
York University, Team S1-G19, Melo-Thaiss Summer 2021 Mitglied von York University, Team S1-G19, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G19
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 37
Letzte 30 Tage: 154
Insgesamt: 4,853
