Einleitung
If a faulty tuning machine on your Sterling by Music Man-StingRay Ray4HH Electric Bass is preventing you from tuning - it's time for a replacement.
This guide can be used to replace non-functioning tuning keys for your Sterling. Before starting the disassembly, make sure to acquire the correct tuning keys and type of string.
Steps 5 & 6 require the use of a drill- it is important to be aware of your environment and take caution.
Was du brauchst
Turn the tuning key counter-clockwise to the loosen string.
Continue turning until there is slack in the string.
Cut the desired string with needle nose pliers.
Remove the string by threading out through the bottom of the bass.
Use a Phillips #1 screwdriver to remove the four 9.53 mm screws.
Remove the broken tuning key.
Adjust the direction of the replacement tuning key as need.
Line up the screw holes of the tuning key to the existing drill holes on the bass.
Secure the four 9.58 mm screws using a drill with the Phillips #2 screwdriver bit.
Thread the string through the bottom of the bass to the new tuning key.
Loop the string around the tuning peg-three to four times-until tight.
This guide will work for any of the tuning keys on a Sterling by Music Man StingRay.
