Zum Hauptinhalt wechseln
How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier
Was du brauchst
  1. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier, Air Filter: Schritt 1, Bild 1 von 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier, Air Filter: Schritt 1, Bild 2 von 2
    • Press the ON/OFF button to power off the machine.
    • The machine is off when the LED light above the ON/OFF button is red.
  2. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 2, Bild 1 von 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 2, Bild 2 von 2
    • Remove the power cord from the back of the machine.
  3. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 3, Bild 1 von 3 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 3, Bild 2 von 3 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 3, Bild 3 von 3
    • On the bottom of the machine, turn the filter cover counter-clockwise.
    • Remove the filter cover.
  4. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 4, Bild 1 von 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 4, Bild 2 von 2
    • Remove the filter from the filter compartment.
  5. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 5, Bild 1 von 1
    • Using the can of compressed air, spray any loose dust out of the empty filter compartment.
  6. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 6, Bild 1 von 1
    • Using a sanitizer wipe, wipe down the inside of the empty filter compartment.
  7. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 7, Bild 1 von 2 How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 7, Bild 2 von 2
    • On the top of the machine, remove the fan cover.
    • Unlike the filter cover, the fan cover can be pried straight off without turning it.
  8. How to Replace the Air Filter for a PARTU BS-03 HEPA Air Purifier: Schritt 8, Bild 1 von 1
    • Using the can of compressed air, spray any dust out of the fan compartment.
Abschluss
To reassemble the air purifier machine, follow these instructions in reverse order.
Ty Washburn
157 Reputation
1 Anleitung geschrieben
4 Kommentare
Does the gadget tells it’s user it’s time to replace it’s air filter? I mean it looks small though to clean and filter the air around it’s surroundings.
Yul Cababan - Antwort
What do 16 beeps mean? Is there a downloadable manual in English to tell me this stuff?
Bruce shier - Antwort
Well is there a manual?
William Bravenec -
Did anyone find a manual for the Partu BS-03 air purifier? I have changed the filter, and reset the filter button. I still hear 3 rapid beeps every 5-10 minutes. Anyone have any insight?
Michael Ratliff - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 25
Letzte 30 Tage: 139
Insgesamt: 6,041
