Einleitung
Replacing the battery in a Kwikset Home Connect 620 Smart Lock is a straightforward process that most people can accomplish at home.
This process presents little opportunity for injury. Even the most novice DIY-er should have no problems following the instructions and performing the repair.
Was du brauchst
Remove the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
Left side
Right side
Bottom
Reattach the three (3) M3 x 6mm screws that secure the faceplate using a #1 Philips screwdriver.
Bottom
Right side
Left side
That's it! Your Kwikset Home Connect 620 Smart Lock should now be working properly.
