Zum Hauptinhalt wechseln
How to Replace the Bearings on a Street Skateboard
Was du brauchst
  1. How to Replace the Bearings on a Street Skateboard, Bearings: Schritt 1, Bild 1 von 1
    • Lay the skateboard on its side so that bearings and axles are facing toward you.
  2. How to Replace the Bearings on a Street Skateboard: Schritt 2, Bild 1 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 2, Bild 2 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 2, Bild 3 von 3
    • Using a skateboard tool or wrench, unscrew the axle nut above the wheel.
    • Remove the wheel from the axle.
  3. How to Replace the Bearings on a Street Skateboard: Schritt 3, Bild 1 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 3, Bild 2 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 3, Bild 3 von 3
    • Position the wheel halfway on the end of the axle.
    • Holding the skateboard down with your other hand, use the end of the axle to pry the bearing out.
  4. How to Replace the Bearings on a Street Skateboard: Schritt 4, Bild 1 von 2 How to Replace the Bearings on a Street Skateboard: Schritt 4, Bild 2 von 2
    • Set the old bearing aside.
    • Repeat the previous step with the other side of the wheel to remove the other bearing.
  5. How to Replace the Bearings on a Street Skateboard: Schritt 5, Bild 1 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 5, Bild 2 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 5, Bild 3 von 3
    • Place a fresh bearing face down (colored side down) onto the axle, and push the wheel down against the metal truck to pop the new bearing in.
    • Hold the skateboard in place with your other hand.
  6. How to Replace the Bearings on a Street Skateboard: Schritt 6, Bild 1 von 1
    • Take the wheel off.
    • Add another fresh bearing onto the axle.
    • Repeat the previous step for the other side of the wheel by pushing the wheel down to pop the bearing in.
  7. How to Replace the Bearings on a Street Skateboard: Schritt 7, Bild 1 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 7, Bild 2 von 3 How to Replace the Bearings on a Street Skateboard: Schritt 7, Bild 3 von 3
    • Place washer(s) onto the axle and then screw the axle nut back on.
    • Repeat steps as needed with other wheels.
Ziellinie
Maxen Hamelynck
157 Reputation
1 Anleitung geschrieben
UC Davis, Team 1-4, Morris Winter 2025 Mitglied von UC Davis, Team 1-4, Morris Winter 2025
UCD-MORRIS-W25S1G4
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 96
