Einleitung
Brakes are one of the most important components on any motorcycle. If your brakes are getting near the end of their life, or you are looking for a brake pad upgrade, this guide will show you how to disassemble your front calipers and replace the brake pads.
Was du brauchst
Place the motorcycle on its center stand to keep the bike upright and stable. If your motorcycle doesn’t have an attached center stand, use a wheel chock or a race stand (front or rear). The kickstand is usable, but will reduce accessibility to the left caliper.
The caliper is attached to the forks by two 12-mm hex bolts. Remove these bolts with a 12mm wrench.
To remove the brake pads, use your flathead screwdriver to remove the cover for the brake pad retainer pin.
After the cover is removed, use the 5mm allen wrench to remove the retainer pin. Do not remove the pin yet, just make sure it is no longer threaded in the caliper.
With a 12mm wrench, unthread the nut that attaches the bracket to the caliper.
Once the nut is fully unthreaded the bracket will slide and rotate upward, exposing the brake pads.
Remove the retainer pin, and the brake pads will fall out.
Use an old toothbrush to scrub the caliper, focusing on the pistons. Try to remove as much of the brake dust as possible.
In order to allow the brake pads to leave a gap large enough for the rotor during re-installation, the pistons must be pushed back into the caliper.
With the bracket extended upwards, hook the end of the brake pad on the retainer clip so the friction pad faces inward, and the hole on the opposite side lines up with the hole for the retainer pin.
Rotate the bracket down. This will cause the retainer clip to clamp down on the edge of the pads.
Thread the bracket nut back into the bracket.
Make sure the pin goes through the holes on the brake pads, and thread the pin into the housing.
Tighten down the retainer pin to 11-14 ft-lbs (15-20 N*m) with the torque wrench.
Place the caliper so that the brake rotor fits in between the pads.
Line up the bracket with the mount on the forks, and using the two 12mm bolts you set aside previously, attach the bracket to the mount. Using a torque wrench, torque the bolts to 17-22 ft-lbs (24-30 N*m)
If you haven't done so already, re-attach the retainer pin cap with a flathead screwdriver.
To replace opposite side brake pads, follow the same procedure.
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Zach Ell: for a latin american, this a priceless professional tool. G. bless your generations forever. Thank so much.
