Zum Hauptinhalt wechseln
How to Replace the Headlight in a 2010-2014 Volkswagen Jetta
Was du brauchst
  1. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: Schritt 1, Bild 1 von 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: Schritt 1, Bild 2 von 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta, Headlight: Schritt 1, Bild 3 von 3
    • Turn the ignition fully off and open the hood of your vehicle.
    • The lever to open it is on the left hand side of the pedals. It’ll make a noticeable clunk sound when pulled the first time which releases the first of the two step hood opening procedure.
    • Make your way to the front of the car and push up on the lever underneath the hood to fully open the hood.
    • Use the hood prop rod to hold the hood open for the duration of the repair.
  2. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 2, Bild 1 von 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 2, Bild 2 von 3 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 2, Bild 3 von 3
    • Locate the plastic dust cover behind the burnt headlight and gently remove it. If the cover is stuck, you can use a screwdriver to pop it out.
  3. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 3, Bild 1 von 2 How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 3, Bild 2 von 2
    • Once the cover is off, twist the light harness from the fixture in a counter clockwise rotation.
    • Pull the bulb to separate it from the connector.
    • Insert the new bulb in the correct orientation as the previous, and tighten it back into the headlight by rotating it clockwise.
  4. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 4, Bild 1 von 1
    • Reapply the dust cover and close the hood of the vehicle.
  5. How to Replace the Headlight in a 2010-2014 Volkswagen Jetta: Schritt 5, Bild 1 von 1
    • Turn the ignition on and switch on the lights to test the new working headlight.
Abschluss
To replace the other headlight. follow the same instructions.
Seyed-Mohammad Hosseiny
159 Reputation
1 Anleitung geschrieben
York University, Team S1-G34, Woodhouse Fall 2020 Mitglied von York University, Team S1-G34, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G34
1 Mitglied
6 Kommentare
Am I missing something? Or is there a trick to those tabs to release the bulb?
Dez Petrovic - Antwort
They are a pull to release mechanism. no need to undo tabs.
Seyed-Mohammad Hosseiny -
Don’t forget to wear gloves when handling halogen light bulbs!
Where’s the driving lights?
Ted Stoffers - Antwort
I installed the new bulb but it still doesn’t work. My neighbor, a retired mechanic came to help and undid both and put back and now, both headlights don’t work. Any other advice?
Emilia Lievano - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 61
Letzte 30 Tage: 357
Insgesamt: 21,739
