Einleitung
If you have an older keyboard such as this Yamaha PSR-330, it may need key replacements and/or repairs. The keys can get sticky, covered in dust and even physically broken. With this guide, you'll be able to remove the keys for a replacement or give it a much needed deep clean to start anew.
Was du brauchst
Unplug and flip the keyboard over.
Remove the 4 inner 25 mm screws using a Phillips screwdriver.
Remove the rest of the 7 mm screws using a Phillips screwdriver.
While holding the back casing, unplug the ribbon cable connecting both front and back casings together.
Set aside the back casing.
Remove both 7 mm Phillips #1 screws from the XR736(C) PCB.
Carefully move the XR736(C) PCB away from the contact pad.
Push down on the black tabs on the contact pad.
Starting from the ends, carefully remove the contact pad by wiggling it out.
Flip over the contact pad.
Using a clean cloth, dust the contact pad and the silicone molds.
Remove the 10 mm Phillips #1 screw(s) from the case.
Flip the keys rights-side up.
Remove the 7 mm Phillips #1 screws from the keys together
Remove the keys in sections using both hands.
Clean the area using a clean cloth and/or compressed air.
4 weitere Personen haben diese Anleitung absolviert.
