Zum Hauptinhalt wechseln
How to Replace the Lightbulbs in a Whirlpool WMH31017HB
Was du brauchst
  1. How to Replace the Lightbulbs in a Whirlpool WMH31017HB, Lightbulbs: Schritt 1, Bild 1 von 1
    • Ensure the underside of the hood is clean, and that there is no oil on it.
    • To remove built-up grease, you can use dish soap and a sponge.
    • Make sure there is no food on the stove.
    • Have the range hood lights on, as you need to be able to see everything.
  2. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 2, Bild 1 von 1
    • Gently unscrew and open the hood panel that is covering the lights with a screwdriver.
  3. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 3, Bild 1 von 1
    • Slowly pull down the lid of the light box.
    • Beware of any shattered light bulbs. To be safe, place a newspaper or a towel under, on the stove. As this catches all the glass and prevents any injuries.
  4. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 4, Bild 1 von 2 How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 4, Bild 2 von 2
    • Turn the lights off.
    • Wait to ensure the lightbulb is cooled down.
    • Do not touch the lightbulb as soon as you have turned it off; it is extremely hot.
  5. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 5, Bild 1 von 1
    • Use a towel to unscrew the light bulbs clockwise from inside the hood or if it is cooled down completely you can use your bare hands.
    • If the bulb has been shattered, ensure that you are twisting the remaining parts carefully. Watch for sharp ends.
  6. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 6, Bild 1 von 1
    • Check the information on the needed light bulb, then purchase a new one. The bulb is 40 W.
    • Often there is a sticker attached to the bulb with the information.
  7. How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 7, Bild 1 von 2 How to Replace the Lightbulbs in a Whirlpool WMH31017HB: Schritt 7, Bild 2 von 2
    • Insert the new lightbulb back and turn it to tighten it.
Abschluss
Close the lid and screw with the screwdriver again.
Shina Salehi
145 Reputation
1 Anleitung geschrieben
York University, Team O-21, Woodhouse Winter 2023 Mitglied von York University, Team O-21, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG21
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 86
Insgesamt: 689
