Einleitung
The side mirror ensures drivers’ safety by allowing them to see the traffic aside and behind them. Broken glass could potentially cause car accidents.
If the side mirror glass on your 2011-2017 Volkswagen Jetta is broken or dirty, use this guide to replace it.
This guide does not require any special skills. Just follow a few steps and you can fit a new mirror to your car!
Was du brauchst
Turn on the accessory power.
Twist the mirror adjustment knob to the side you are working on (L for left, R for right).
Push the knob so that the mirror will angle towards the car.
Turn off the accessory power.
Turn the accessory power on.
Using the adjustment knob, move the mirror back to a normal viewing angle.
Follow these instructions for either side mirror. The only difference will be which mirror you adjust using the mirror adjustment knob in step 1.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
