Zum Hauptinhalt wechseln
How to Replace the Training Wheels on a Schwinn 12” Kids' Bike
Was du brauchst
  1. How to Replace the Training Wheels on a Schwinn 12” Kids' Bike, Training Wheels: Schritt 1, Bild 1 von 1
    • Flip the bike upside-down for stability.
  2. How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 2, Bild 1 von 3 How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 2, Bild 2 von 3 How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 2, Bild 3 von 3
    • Use a 15mm socket wrench, and remove the wheel arm bolt securing the wheel arm.
    • Remove the damaged wheel arm.
  3. How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 3, Bild 1 von 3 How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 3, Bild 2 von 3 How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 3, Bild 3 von 3
    • To replace a damaged wheel, use a 13 mm socket and a Phillips screwdriver, and remove the wheel screw fastening the wheel to the wheel arm.
    • The screw may be hidden behind the bike's design theme. If this is the case, poke through the label to reach the screw in the center of the wheel.
    • Replace the damaged wheel and secure it with the screw you just removed from the old wheel.
  4. How to Replace the Training Wheels on a Schwinn 12” Kids' Bike: Schritt 4, Bild 1 von 1
    • Realign the wheel arm with the rear bolt placement and secure it with the wheel arm bolt.
    • Replace the damaged wheel arm prior to securing it in place.
Abschluss
Brian Gibson
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 135
