Zum Hauptinhalt wechseln
How to Replace the Wax Ring on a Toilet
Was du brauchst
  1. How to Replace the Wax Ring on a Toilet, Wax Ring: Schritt 1, Bild 1 von 1
    • Turn off the water.
    • You do not want to forget this step.
  2. How to Replace the Wax Ring on a Toilet: Schritt 2, Bild 1 von 1
    • Disconnect the hose from the toilet by unscrewing the white plastic connector.
    • Excess water will spill out of this pipe, so have a bucket or rag nearby to catch it!
  3. How to Replace the Wax Ring on a Toilet: Schritt 3, Bild 1 von 1
    • Remove the plastic bolt protectors on either side of the base of the toilet.
    • Using a wrench, remove the nuts and washers from the bottom of the toilet where it's bolted to the floor.
    • Lift the toilet up from the floor.
    • Use caution when lifting it, it's going to be heavy!
    • Set the toilet off to the side.
  4. How to Replace the Wax Ring on a Toilet: Schritt 5, Bild 1 von 1
    • Remove the old wax ring and any debris from the toilet pipe in the floor where the toilet was, being sure not to let any debris fall down the pipe.
    • It may be nice to wear gloves for this step, as the old wax ring will be a bit dirty.
  5. How to Replace the Wax Ring on a Toilet: Schritt 6, Bild 1 von 1
    • Place new ring in the proper position for your toilet to rest on.
    • Carefully position the toilet back over the hole, paying attention to the bolts.
  6. How to Replace the Wax Ring on a Toilet: Schritt 7, Bild 1 von 1
    • Tighten the nuts and bolts on each side of the toilet and replace the bolt-protectors.
Abschluss
Make sure you wash your hands!
Ahna Hensley
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 93
Insgesamt: 1,885
