Einleitung
Regular maintenance of your vacuum cleaner is essential for optimum performance and longevity. The filters, responsible for trapping dust and particles, need replacement to ensure your vacuum operates at its best. Neglecting this aspect can lead to reduced suction power and decreased air quality in your living space. Though this filter can be washed, after awhile it may tear or become too worn and will need to be replaced.
If you need to replace the filter of your iwoly V600 stick vacuum cleaner, follow this guide.
Before you begin, turn off the vacuum, unplug the device from the outlet, and remove all attachments.
Was du brauchst
Press down on the lever located on the front of the vacuum, beneath the attachment, to release the filter lid.
Verify that you have the correct filter designed for the iwoly V600 vacuum cleaner.
