Zum Hauptinhalt wechseln
How to Replace the iwoly V600 Vacuum Filter
Was du brauchst
  1. How to Replace the iwoly V600 Vacuum Filter, Filter: Schritt 1, Bild 1 von 3 How to Replace the iwoly V600 Vacuum Filter, Filter: Schritt 1, Bild 2 von 3 How to Replace the iwoly V600 Vacuum Filter, Filter: Schritt 1, Bild 3 von 3
    • Before you begin, ensure the vacuum is unplugged from the power outlet.
    • Press down on the lever located on the front of the vacuum, beneath the attachment, to release the filter lid.
  2. How to Replace the iwoly V600 Vacuum Filter: Schritt 2, Bild 1 von 2 How to Replace the iwoly V600 Vacuum Filter: Schritt 2, Bild 2 von 2
    • Turn the orange filter cover counterclockwise to remove it and set it aside.
  3. How to Replace the iwoly V600 Vacuum Filter: Schritt 3, Bild 1 von 2 How to Replace the iwoly V600 Vacuum Filter: Schritt 3, Bild 2 von 2
    • Unscrew the filter and remove it from the vacuum.
  4. How to Replace the iwoly V600 Vacuum Filter: Schritt 4, Bild 1 von 1
    • Verify that you have the correct filter designed for the iwoly V600 vacuum cleaner.
  5. How to Replace the iwoly V600 Vacuum Filter: Schritt 5, Bild 1 von 3 How to Replace the iwoly V600 Vacuum Filter: Schritt 5, Bild 2 von 3 How to Replace the iwoly V600 Vacuum Filter: Schritt 5, Bild 3 von 3
    • Ensure the new filter is correctly positioned.
    • Screw it in securely.
  6. How to Replace the iwoly V600 Vacuum Filter: Schritt 6, Bild 1 von 2 How to Replace the iwoly V600 Vacuum Filter: Schritt 6, Bild 2 von 2
    • Replace the orange filter cover.
    • Rotate it clockwise to ensure a proper seal.
  7. How to Replace the iwoly V600 Vacuum Filter: Schritt 7, Bild 1 von 1
    • Close the vacuum filter lid securely.
    • Your task is complete. Happy vacuuming!
Abschluss
Sam Haddad
145 Reputation
1 Anleitung geschrieben
York University, Team 2-12, O'Regan Winter 2024 Mitglied von York University, Team 2-12, O'Regan Winter 2024
YORK-O'REGAN-W24S2G12
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 48
