Einleitung
This guide will demonstrate how to increase the life of the air filter for the Honda HRR216 lawnmower.
Maintaining the filter is something that I do after every summer due to how often I use the lawnmower.
Steps 1,2,5, and 6 in this guide can also be used for removing or replacing the filter, as it will eventually wear down.
Was du brauchst
Seat the filter in the same position you made a note of in Step 2.
Place the cover onto the air filter. This shouldn't require any force, so the filter may need to be readjusted if it does require force.
Push the clips of the cover in until they click.
Check to make sure that the cover is secure, and there are no gaps for dirt or dust to get in.
Eine weitere Person hat diese Anleitung absolviert.
