Zum Hauptinhalt wechseln
How to Reset your Dell Printer Factory Setting and Cartridge
  1. How to Reset your Dell Printer Factory Setting and Cartridge, Reset Dell Printer to Factory Setting: Schritt 1, Bild 1 von 1
    • Open a Web program and type the printer's IP address to get to its Web comfort. Your system director ought to have the printer's IP address, or you may almost certainly discover it by printing an arrangement page. Normally, squeezing and holding the "Proceed" catch will produce the page.
    • Sign in to the comfort - your system director ought to have this data - and search for the "Reset Print Server" alternative, normally situated in a segment marked "Printer settings" or comparable.
    • Shut the printer off and unplug it. Leave the printer unplugged for five minutes. Fitting it back in and turn it on.
  2. How to Reset your Dell Printer Factory Setting and Cartridge, Reset your Dell Printer Cartridge: Schritt 2, Bild 1 von 1
    • Addition the refilled inkjet cartridge in your Dell printer and turn off the printer for no less than five seconds.
    • Turn on the printer and you'll see a Dell print utility discourse window open on your PC screen. The window shows a notice that your print level is underneath the base dimension. In the event that this window doesn't dispatch naturally, open a report and endeavor to print. .
    • Uncheck the "Total a-Print" check box. Just underneath it you'll see the "Don't Display This Dialog Again" box; check it.
    • Click on OK or "Keep Printing," contingent upon whether you're on the startup cautioning page or in the event that you endeavored to print a report, individually. This resets your ink level.
Abschluss
Sofia james
141 Reputation
1 Anleitung geschrieben
3 Kommentare
Hi, my Dell printer won't let me print and will not connect to the internet. Any ideas now?
Dakota Fleming - Antwort
try resetting your printer
Claude Rixon - Antwort
Hello can dell 3460dn cartridge be resetted ?
musa King - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 59
Insgesamt: 3,726
