Zum Hauptinhalt wechseln
How to Reshape a Warped Nail Polish Brush
Was du brauchst
    1. How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: Schritt 1, Bild 1 von 2 How to Reshape a Warped Nail Polish Brush, How to Reshape a Warped Nail Polish Brush: Schritt 1, Bild 2 von 2
      • Remove the nail polish brush from bottle.
      • Wrap the bottle of nail polish with aluminum foil to prevent the polish from drying.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Reshape a Warped Nail Polish Brush: Schritt 2, Bild 1 von 2 How to Reshape a Warped Nail Polish Brush: Schritt 2, Bild 2 von 2
      • Wipe the brush clean with a paper towel.
      Frag FixBot
    3. How to Reshape a Warped Nail Polish Brush: Schritt 3, Bild 1 von 2 How to Reshape a Warped Nail Polish Brush: Schritt 3, Bild 2 von 2
      • Clean the brush in small amount of 100% pure acetone in a glass bowl.
      • DO NOT USE ANY OTHER TYPE OF CONTAINER MATERIALS OTHER THAN GLASS or PORCELAIN FOR ACETONE. Acetone is a chemical that will damage the plastic’s surface by softening it, smearing it, or even dissolving the plastic.
      Frag FixBot
    4. How to Reshape a Warped Nail Polish Brush: Schritt 4, Bild 1 von 1
      • Blow-dry the brush on medium-low heat from brush base to tip for 30-90 seconds.
      Frag FixBot
    5. How to Reshape a Warped Nail Polish Brush: Schritt 5, Bild 1 von 3 How to Reshape a Warped Nail Polish Brush: Schritt 5, Bild 2 von 3 How to Reshape a Warped Nail Polish Brush: Schritt 5, Bild 3 von 3
      • Reshape the warm bristles by hand or press in a book, rotating as needed.
      • You can reheat the bristles if they are not yet flattened into the desired shape.
      Frag FixBot
Abschluss
Test a swatch on a piece of paper to check the shape of the brush with the nail polish. If the shape is not yet to its desired form, restart the guide to reshape the brush.
Michelle Nguyen
130 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 55
Insgesamt: 2,190
