Zum Hauptinhalt wechseln
How to Resize Baggy Overalls
Was du brauchst
  1. How to Resize Baggy Overalls, How to Resize Baggy Overalls: Schritt 1, Bild 1 von 3 How to Resize Baggy Overalls, How to Resize Baggy Overalls: Schritt 1, Bild 2 von 3 How to Resize Baggy Overalls, How to Resize Baggy Overalls: Schritt 1, Bild 3 von 3
    • Try on the overalls.
    • Take your ruler and measure from the bottom of the crotch up to the desired crotch point.
    • Take note of your measurements.
  2. How to Resize Baggy Overalls: Schritt 2, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 2, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 2, Bild 3 von 3
    • Flip the overalls inside out and lay them flat.
    • Use the ruler to place the recorded intake length measured in Step 1.
    • Mark the top of this measurement on the center seam of the overalls.
  3. How to Resize Baggy Overalls: Schritt 3, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 3, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 3, Bild 3 von 3
    • Using your fabric chalk, draw an angled line from the top of your crotch point to blend seamlessly with the bottom of your inseam.
    • Measure the line just marked.
    • Repeat measurements on the other side.
  4. How to Resize Baggy Overalls: Schritt 4, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 4, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 4, Bild 3 von 3
    • Take your pins and pin them downwards along both lines.
    • Make sure to pin on both sides of the fabric and leave about 3" of spacing between each pin.
    • Be careful not to prod your fingers when pinning the fabric.
  5. How to Resize Baggy Overalls: Schritt 5, Bild 1 von 2 How to Resize Baggy Overalls: Schritt 5, Bild 2 von 2
    • Try on the pinned overalls to ensure a comfortable fit.
    • If the measurements still need adjustment, head to Step 6.
    • If the measurements are perfect, head to Step 7.
    • Be careful when trying on the overalls. Wear a pair of long pants under to protect from being poked.
  6. How to Resize Baggy Overalls: Schritt 6, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 6, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 6, Bild 3 von 3
    • Lay your overalls back on a flat surface.
    • Take your fabric chalk and redraw your new measurements
    • Re-pin your new measurements.
  7. How to Resize Baggy Overalls: Schritt 7, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 7, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 7, Bild 3 von 3
    • Sewing machine set up will vary with each machine. Refer to the article in the introduction on How to Use a Sewing Machine as needed.
    • Bring your overalls under the sewing needle and line the needle to the top of the crotch marker.
    • Gently press the foot pedal below to slowly start moving your fabric along your chalk line.
    • When you reach a pin, pause machine before removing.
    • Run the machine through the end of your marker point.
    • Cut the excess thread after the pass.
  8. How to Resize Baggy Overalls: Schritt 8, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 8, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 8, Bild 3 von 3
    • Cut the fabric along the sewn seam.
    • Leave half an inch of fabric from your seam to prevent loosening.
  9. How to Resize Baggy Overalls: Schritt 9, Bild 1 von 3 How to Resize Baggy Overalls: Schritt 9, Bild 2 von 3 How to Resize Baggy Overalls: Schritt 9, Bild 3 von 3
    • Flip your overalls inside out.
    • Try them on and you're done!
Abschluss
Emily Le
169 Reputation
1 Anleitung geschrieben
UC Davis, Team 2-1, Andersen Winter 2024 Mitglied von UC Davis, Team 2-1, Andersen Winter 2024
UCD-ANDERSEN-W24S2G1
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 24
Letzte 30 Tage: 123
Insgesamt: 1,564
