Einleitung
Do you have a metal ring that you love, but cannot wear? Is that metal ring too large to wear on your finger? Do you have insufficient funds to go to a professional jeweler? Do you have no experience with soldering?
This guide will show you how to safely resize a metal ring that is too large for your finger by creating a mold out of soft, polymer clay and then trimming the mold, so that it acts as an insert. While the guide suggests this is a two day process, it requires x hours for the clay to dry into a mold
For this repair, you will need soft, polymer clay, scissors, and super glue rather than heat-based repairs. Also, drying is required, which will
Warning: minimize contact with the super glue and your skin.
Was du brauchst
Find the metal ring that is too large for your finger.
Wear the metal ring.
Place the back of your hand flat on a table.
Shape the soft clay snugly in the gap between the metal ring and your finger.
Remove your finger slowly from the molded soft clay, immediately after shaping the soft clay.
Wait for the soft clay to dry overnight.
Use scissors to trim the mold's extra soft clay sticking out of the metal ring.
Adhere super glue on the soft clay mold that will touch the metal ring.
Attach the soft clay mold to the metal ring before the super glue dries.
Wait 10 minutes for the super glue to dry.
Trim the soft clay with scissors again, if needed.
