Zum Hauptinhalt wechseln
How to Resize a Metal Ring that is Too Large
Was du brauchst
  1. How to Resize a Metal Ring that is Too Large, How to Resize a Metal Ring that is Too Large: Schritt 1, Bild 1 von 2 How to Resize a Metal Ring that is Too Large, How to Resize a Metal Ring that is Too Large: Schritt 1, Bild 2 von 2
    • Find the metal ring that is too large for your finger.
  2. How to Resize a Metal Ring that is Too Large: Schritt 2, Bild 1 von 2 How to Resize a Metal Ring that is Too Large: Schritt 2, Bild 2 von 2
    • Tear off a quarter size of soft clay.
    • The soft clay will act as a mold that will enlarge the metal ring.
  3. How to Resize a Metal Ring that is Too Large: Schritt 3, Bild 1 von 3 How to Resize a Metal Ring that is Too Large: Schritt 3, Bild 2 von 3 How to Resize a Metal Ring that is Too Large: Schritt 3, Bild 3 von 3
    • Wear the metal ring.
    • Place the back of your hand flat on a table.
    • Shape the soft clay snugly in the gap between the metal ring and your finger.
  4. How to Resize a Metal Ring that is Too Large: Schritt 4, Bild 1 von 3 How to Resize a Metal Ring that is Too Large: Schritt 4, Bild 2 von 3 How to Resize a Metal Ring that is Too Large: Schritt 4, Bild 3 von 3
    • Remove your finger slowly from the molded soft clay, immediately after shaping the soft clay.
    • If the molded soft clay shifts then repeat Step 3.
    • Wait for the soft clay to dry overnight.
    • To tell if the soft clay is dry, touch the soft clay to see if it has hardened.
  5. How to Resize a Metal Ring that is Too Large: Schritt 5, Bild 1 von 3 How to Resize a Metal Ring that is Too Large: Schritt 5, Bild 2 von 3 How to Resize a Metal Ring that is Too Large: Schritt 5, Bild 3 von 3
    • Remove the soft clay mold from the metal ring.
  6. How to Resize a Metal Ring that is Too Large: Schritt 6, Bild 1 von 2 How to Resize a Metal Ring that is Too Large: Schritt 6, Bild 2 von 2
    • Use scissors to trim the mold's extra soft clay sticking out of the metal ring.
  7. How to Resize a Metal Ring that is Too Large: Schritt 7, Bild 1 von 3 How to Resize a Metal Ring that is Too Large: Schritt 7, Bild 2 von 3 How to Resize a Metal Ring that is Too Large: Schritt 7, Bild 3 von 3
    • Limit super glue exposure from skin as it may cause a rash. If super glue comes into contact with skin, soak the skin in warm, soapy water.
    • Adhere super glue on the soft clay mold that will touch the metal ring.
    • Attach the soft clay mold to the metal ring before the super glue dries.
  8. How to Resize a Metal Ring that is Too Large: Schritt 8, Bild 1 von 3 How to Resize a Metal Ring that is Too Large: Schritt 8, Bild 2 von 3 How to Resize a Metal Ring that is Too Large: Schritt 8, Bild 3 von 3
    • Wait 10 minutes for the super glue to dry.
    • Trim the soft clay with scissors again, if needed.
    • The goal of this step is to align the soft clay mold along the metal ring's band.
  9. How to Resize a Metal Ring that is Too Large: Schritt 9, Bild 1 von 2 How to Resize a Metal Ring that is Too Large: Schritt 9, Bild 2 von 2
    • If completed, the metal ring should fit!
Ziellinie
Helena Sherman
169 Reputation
1 Anleitung geschrieben
UC Davis, Team S2-G1, Andersen Winter 2020 Mitglied von UC Davis, Team S2-G1, Andersen Winter 2020
UCD-ANDERSEN-W20S2G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 312
