Zum Hauptinhalt wechseln
How to Restain Wood
Was du brauchst
  1. How to Restain Wood, How to Restain Wood: Schritt 1, Bild 1 von 1
    • Wipe down the wood with a rag or a towel to take clean the wood.
  2. How to Restain Wood: Schritt 2, Bild 1 von 1
    • Sand down the wood until you get a soft surface.
    • If your wood is already stained, then sand the wood until it is clear of the old stain.
  3. How to Restain Wood: Schritt 3, Bild 1 von 1
    • Wipe down the sanded part with the rag so when you paint on the wood you don't get the brush dirty with dust from the wood.
  4. How to Restain Wood: Schritt 4, Bild 1 von 1
    • Paint the wood and make sure to cover all surfaces of the wood.
    • Let it dry and repaint the wood a couple more times to ensure all of the surfaces have been properly coated.
Abschluss
To do this process again just follow these steps again and this process should be done again in 6-7 months
Brian Morales
109 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S12-G9, Harris Fall 2020 Mitglied von CSU Los Angeles, Team S12-G9, Harris Fall 2020
CSULA-HARRIS-F20S12G9
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 245
