Zum Hauptinhalt wechseln
How to Restore Synthetic Wig Quality
Was du brauchst
    1. How to Restore Synthetic Wig Quality, How to Restore Synthetic Wig Quality: Schritt 1, Bild 1 von 1
      • Fill your container of choice with warm to hot water (enough to cover the entire wig).
      Frag FixBot
      Kommentar hinzufügen
    2. How to Restore Synthetic Wig Quality: Schritt 2, Bild 1 von 1
      • To make sure your wig is fully moisturized, add shampoo before and after putting the synthetic wig in the container.
      • Apply the hair shampoo of your choice into the container.
      • If using a bottle with a pump, apply 5-7 pumps of shampoo to the water. If using a squeeze bottle, count to 5 seconds while pouring shampoo into the water.
      • Mix shampoo into the water thoroughly.
      Frag FixBot
    3. How to Restore Synthetic Wig Quality: Schritt 3, Bild 1 von 2 How to Restore Synthetic Wig Quality: Schritt 3, Bild 2 von 2
      • Place the synthetic wig into the container
      • Make sure the wig is completely under water.
      Frag FixBot
    4. How to Restore Synthetic Wig Quality: Schritt 4, Bild 1 von 2 How to Restore Synthetic Wig Quality: Schritt 4, Bild 2 von 2
      • If using a bottle with a pump, apply 5-7 pumps of shampoo to the water. If using a squeeze bottle, count to 5 (seconds) while pouring shampoo into the water.
      • Mix shampoo into the water to clean and moisturize the wig thoroughly.
      • Leave the synthetic wig in the container for 15-20 minutes. The longer you leave it in, the softer your wig will be.
      Frag FixBot
    5. How to Restore Synthetic Wig Quality: Schritt 5, Bild 1 von 3 How to Restore Synthetic Wig Quality: Schritt 5, Bild 2 von 3 How to Restore Synthetic Wig Quality: Schritt 5, Bild 3 von 3
      • Rinse the shampoo from the synthetic wig with warm water from the bottom to the top.
      Frag FixBot
    6. How to Restore Synthetic Wig Quality: Schritt 6, Bild 1 von 1
      • Comb or brush through your synthetic wig to remove knots and tangles, from the bottom to the top.
      • For straight hair synthetic wigs: you can use a small-tooth comb or hair detangler brush.
      • For wavy to loose curl synthetic wigs: you can use a wide-tooth comb or hair detangler brush.
      • There should be no restriction after a full comb or brush through.
      Frag FixBot
    7. How to Restore Synthetic Wig Quality: Schritt 7, Bild 1 von 1
      • Dump the old water from the container and fill it with fresh, warm to hot water.
      Frag FixBot
    8. How to Restore Synthetic Wig Quality: Schritt 8, Bild 1 von 3 How to Restore Synthetic Wig Quality: Schritt 8, Bild 2 von 3 How to Restore Synthetic Wig Quality: Schritt 8, Bild 3 von 3
      • Add the synthetic wig back into the fresh water in your container. Apply the hair conditioner of your choice into the container.
      • To make sure your wig is fully moisturized, add conditioner before and after putting the synthetic wig in the container.
      • If using Silicon Mix, apply 2-3 spoonfuls into the water.
      • If using a bottle with a pump, apply 5-7 pumps of conditioner to the water.
      • If using a squeeze bottle, count to 5 (seconds) while pouring the conditioner into the water.
      • Mix conditioner into the water to moisturize the wig thoroughly.
      • Leave the synthetic wig in the container for 20-30 minutes. The longer you leave it in, the softer your wig will be.
      Frag FixBot
    9. How to Restore Synthetic Wig Quality: Schritt 9, Bild 1 von 2 How to Restore Synthetic Wig Quality: Schritt 9, Bild 2 von 2
      • Rinse the conditioner or Silicon Mix from the wig with warm water from the bottom to the top.
      • Ring out excess water from your wig.
      • Do one last comb or brush through to make sure there are no more tangles or knots in the wig.
      • Pat dry with a soft microfiber towel.
      Frag FixBot
    10. How to Restore Synthetic Wig Quality: Schritt 10, Bild 1 von 3 How to Restore Synthetic Wig Quality: Schritt 10, Bild 2 von 3 How to Restore Synthetic Wig Quality: Schritt 10, Bild 3 von 3
      • Apply the wig to the mannequin head.
      • Using pins can keep the wig secure through the drying process.
      • Leave wig on the mannequin head to dry for one day.
      • For immediate use of wig, dry with hair dryer on medium to low heat.
      • For straight hair synthetic wigs: dry it normally.
      • For synthetic wigs with wavy to loose curls: the curl pattern should return after drying. For more security, add curlers to the hair, following the curl pattern, while drying.
      Frag FixBot
    11. How to Restore Synthetic Wig Quality: Schritt 11, Bild 1 von 1
      • After the drying process, your synthetic wig should look good as new!
      • For maximum shine and hold, add hair spray after drying.
      • For straight synthetic wigs: if you are experiencing any small hairs that are sticking out after the drying process, use a flat iron on medium to high heat.
      • For wavy or loose curl synthetic wigs: if you are experiencing any small hairs that are sticking out after the drying process, use a curling iron (or flat iron) on medium to high heat and follow the curl pattern of the wig.
      Frag FixBot
    12. How to Restore Synthetic Wig Quality: Schritt 12, Bild 1 von 1
      • Before
      Frag FixBot
    13. How to Restore Synthetic Wig Quality: Schritt 13, Bild 1 von 1
      • After
      Frag FixBot
Ziellinie
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 28
Letzte 30 Tage: 85
Insgesamt: 5,740
