Zum Hauptinhalt wechseln
How to Restore Wool’s Water Resistance
Was du brauchst
  1. How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: Schritt 1, Bild 1 von 3 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: Schritt 1, Bild 2 von 3 How to Restore Wool’s Water Resistance, How to Restore Wool’s Water Resistance: Schritt 1, Bild 3 von 3
    • Fill a bowl with water at room temperature (20 °C or 68 °F).
    • Use 2 L of water per 200 g of wool.
  2. How to Restore Wool’s Water Resistance: Schritt 2, Bild 1 von 1
    • Add 1/2 teaspoon of wool wash per 2 L of water.
  3. How to Restore Wool’s Water Resistance: Schritt 3, Bild 1 von 2 How to Restore Wool’s Water Resistance: Schritt 3, Bild 2 von 2
    • Insert the articles into the bowl and let soak for 30 minutes.
    • Carefully squeeze the items to allow absorption of soap and water through the wool fibres.
  4. How to Restore Wool’s Water Resistance: Schritt 4, Bild 1 von 1
    • Lift the items out of the water and gently squeeze to remove excess water and soap.
  5. How to Restore Wool’s Water Resistance: Schritt 5, Bild 1 von 1
    • Refill the bowl with room temperature water.
    • Use the same volume of water as in Step 1.
  6. How to Restore Wool’s Water Resistance: Schritt 6, Bild 1 von 2 How to Restore Wool’s Water Resistance: Schritt 6, Bild 2 von 2
    • Mix 4 tablespoons of emulsified lanolin into 2 liters of water.
  7. How to Restore Wool’s Water Resistance: Schritt 7, Bild 1 von 2 How to Restore Wool’s Water Resistance: Schritt 7, Bild 2 von 2
    • Add the articles and squeeze to saturate.
    • Weight the articles with a heavy glass or a dish.
    • Leave to soak for 30 minutes.
  8. How to Restore Wool’s Water Resistance: Schritt 8, Bild 1 von 2 How to Restore Wool’s Water Resistance: Schritt 8, Bild 2 von 2
    • Pull the articles out of the lanolin bath and gently squeeze out excess water.
  9. How to Restore Wool’s Water Resistance: Schritt 9, Bild 1 von 1
    • Lay flat to dry with a clean towel beneath the items.
    • Do not line dry. It can cause wool to stretch and lose shape.
    • Avoid direct sunlight or direct heat when drying.
Ziellinie
Yuliya S
169 Reputation
1 Anleitung geschrieben
York University, Team 1-26, O'Regan Winter 2022 Mitglied von York University, Team 1-26, O'Regan Winter 2022
YORK-O'REGAN-W22S1G26
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 495
