Zum Hauptinhalt wechseln
How to Restore a Dining Chair
Was du brauchst
    1. How to Restore a Dining Chair, How to Restore a Dining Chair: Schritt 1, Bild 1 von 3 How to Restore a Dining Chair, How to Restore a Dining Chair: Schritt 1, Bild 2 von 3 How to Restore a Dining Chair, How to Restore a Dining Chair: Schritt 1, Bild 3 von 3
      • Begin with an old chair frame.
      • For frames in good condition, continue to step 5.
      • Using your sandpaper, rub any marks or scuffs off the wood.
      • Always rub with the grain of the wood.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Restore a Dining Chair: Schritt 2, Bild 1 von 2 How to Restore a Dining Chair: Schritt 2, Bild 2 von 2
      • Use the cleaning cloth to wipe off any excess dirt and dust.
      Frag FixBot
    3. How to Restore a Dining Chair: Schritt 3, Bild 1 von 3 How to Restore a Dining Chair: Schritt 3, Bild 2 von 3 How to Restore a Dining Chair: Schritt 3, Bild 3 von 3
      • Holding the spray paint 6-12 inches away from the chair, apply a light coat of paint.
      • Allow it to dry for about 5 minutes.
      • Apply a second light coat over the front of the chair and allow it to dry for 10 minutes.
      Frag FixBot
    4. How to Restore a Dining Chair: Schritt 4, Bild 1 von 2 How to Restore a Dining Chair: Schritt 4, Bild 2 von 2
      • Flip the chair over.
      • Repeat step 3 for the back side.
      Frag FixBot
    5. How to Restore a Dining Chair: Schritt 5, Bild 1 von 3 How to Restore a Dining Chair: Schritt 5, Bild 2 von 3 How to Restore a Dining Chair: Schritt 5, Bild 3 von 3
      • While the paint dries, work on the seat.
      • Grab the wood board and set it down.
      • Grab the desired cushion and rest it on top of the board.
      • Make sure to align all four corners of the wood to the corners of the cushion.
      Frag FixBot
    6. How to Restore a Dining Chair: Schritt 6, Bild 1 von 3 How to Restore a Dining Chair: Schritt 6, Bild 2 von 3 How to Restore a Dining Chair: Schritt 6, Bild 3 von 3
      • Now grab the cushion cover.
      • You may use fabric (cut to size) instead of a cushion cover.
      • Place your cover on top of the cushion, aligning all four corners.
      Frag FixBot
    7. How to Restore a Dining Chair: Schritt 7, Bild 1 von 3 How to Restore a Dining Chair: Schritt 7, Bild 2 von 3 How to Restore a Dining Chair: Schritt 7, Bild 3 von 3
      • Grab the stack of wood, cushion and cover and flip it over.
      • Align them so they stack up evenly.
      • Fragments of the cushion cover may stick out a little.
      Frag FixBot
    8. How to Restore a Dining Chair: Schritt 8, Bild 1 von 3 How to Restore a Dining Chair: Schritt 8, Bild 2 von 3 How to Restore a Dining Chair: Schritt 8, Bild 3 von 3
      • Fold the sides of the cover over the board and cushion keeping them as close to the center of the board as possible.
      • Select a side to start on.
      • With the staple gun, staple the end of the cushion cover you are holding into the board.
      • Rotate the board and staple down the other side.
      • Continue to staple down the sides, placing staples about 1 inch apart.
      • Fold the corners in and staple them onto the board.
      Frag FixBot
    9. How to Restore a Dining Chair: Schritt 9, Bild 1 von 3 How to Restore a Dining Chair: Schritt 9, Bild 2 von 3 How to Restore a Dining Chair: Schritt 9, Bild 3 von 3
      • Make sure that the paint on the chair frame has completely dried up.
      • Grab your newly covered cushion and place it on the seat of the chair frame.
      • Holding on to both the cushion and the frame, flip the chair over.
      Frag FixBot
    10. How to Restore a Dining Chair: Schritt 10, Bild 1 von 3 How to Restore a Dining Chair: Schritt 10, Bild 2 von 3 How to Restore a Dining Chair: Schritt 10, Bild 3 von 3
      • Place the screws in the screw holes.
      • Tighten the screws with the philips screw driver.
      • To avoid the wood from cracking, do not apply to much force when turning screwdriver.
      Frag FixBot
    11. How to Restore a Dining Chair: Schritt 11, Bild 1 von 1
      • Make good use of your brand new chair.
      Frag FixBot
Ziellinie
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 15-6, Green Fall 2015 Mitglied von Cal Poly, Team 15-6, Green Fall 2015
CPSU-GREEN-F15S15G6
5 Mitglieder
9 Anleitungen geschrieben
2 Kommentare zur Anleitung
Do you have any Ideas on fixing a wobble chair before replacing the seat ?
Robert - Antwort Teilen
Hi, I have a aoks chair I want to restore can you please help
Josefina Mejia - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 44
Insgesamt: 7,440
