Zum Hauptinhalt wechseln
How to Restore a Torn Nike Flip-Flop
Was du brauchst
  1. How to Restore a Torn Nike Flip-Flop, How to Restore a Torn Nike Flip-Flop: Schritt 1, Bild 1 von 1
    • Remove all rough edges with 120 grit sandpaper from the torn parts of the flip-flop.
  2. How to Restore a Torn Nike Flip-Flop: Schritt 2, Bild 1 von 2 How to Restore a Torn Nike Flip-Flop: Schritt 2, Bild 2 von 2
    • Clean off any additional residue with soap, water, and a towel or toothbrush.
    • Allow the flip-flop to air dry before moving on.
  3. How to Restore a Torn Nike Flip-Flop: Schritt 3, Bild 1 von 1
    • Gently apply the adhesive on the torn parts of the flip-flop.
    • Make sure the torn parts are completely covered. Overspill is okay.
    • Connect and hold the parts of the flip-flop to the adhesive with your hands for 5 minutes. After the 5 minutes the adhesive will be hard enough to let it sit. Let the adhesive dry for 24 hours.
    • Be sure to wear gloves and be in a ventilated environment when applying the adhesive.
  4. How to Restore a Torn Nike Flip-Flop: Schritt 4, Bild 1 von 1
    • Once the adhesive is dry remove any extra adhesive that might have spilled over with the sandpaper.
  5. How to Restore a Torn Nike Flip-Flop: Schritt 5, Bild 1 von 3 How to Restore a Torn Nike Flip-Flop: Schritt 5, Bild 2 von 3 How to Restore a Torn Nike Flip-Flop: Schritt 5, Bild 3 von 3
    • Take the needle and thread and begin to sew a cross stitch from the strap to the torn part of the flip-flop.
    • It may be easier to use an upholstery needle to get through the rubber material.
  6. How to Restore a Torn Nike Flip-Flop: Schritt 6, Bild 1 von 1
    • Cover the stitched region with Plasti Dip.
    • Allow 4 hours to dry.
    • Make sure to apply the Plastic Dip in a proper environment with venalation or outside.
Abschluss
The Nike Flip-Flop(s) are now restored and can be worn again.
7 weitere Personen haben diese Anleitung absolviert.
Texas Tech, Team S1-G2, Rauch Summer 2017 Mitglied von Texas Tech, Team S1-G2, Rauch Summer 2017
TTU-RAUCH-SU17S1G2
2 Mitglieder
2 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hi Andrew! Thank you so much for this example. What kind of adhesive did you use, because there are so many versions. Thank you.
masood daud - Antwort
Oh darn I see it now.lol
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 80
Insgesamt: 19,271
