Zum Hauptinhalt wechseln
How to Restore a Used Canvas
Was du brauchst
  1. How to Restore a Used Canvas, How to Restore a Used Canvas: Schritt 1, Bild 1 von 2 How to Restore a Used Canvas, How to Restore a Used Canvas: Schritt 1, Bild 2 von 2
    • Insert a spudger beneath a staple and pry upwards to remove it.
    • Repeat for the remaining staples.
    • Caution: Be careful when handling sharp staples.
  2. How to Restore a Used Canvas: Schritt 2, Bild 1 von 2 How to Restore a Used Canvas: Schritt 2, Bild 2 von 2
    • Remove the canvas and place the wood frame aside
    • Lay out the used canvas flat on a clean surface.
    • Wipe the canvas down with a damp cloth.
  3. How to Restore a Used Canvas: Schritt 3, Bild 1 von 1
    • Gently use fine grit sandpaper to remove any old clumps of paint on the canvas.
  4. How to Restore a Used Canvas: Schritt 4, Bild 1 von 3 How to Restore a Used Canvas: Schritt 4, Bild 2 von 3 How to Restore a Used Canvas: Schritt 4, Bild 3 von 3
    • Add an even layer of white acrylic paint on the entire canvas.
    • Use a paintbrush to evenly spread the paint on the canvas.
  5. How to Restore a Used Canvas: Schritt 5, Bild 1 von 1
    • To make the drying process faster, use a portable fan or hairdryer.
    • Continue to paint even layers until the canvas is covered evenly.
  6. How to Restore a Used Canvas: Schritt 6, Bild 1 von 1
    • After the paint is completely dry, lightly sand down any noticeable bumps to get a smooth finish on the canvas.
  7. How to Restore a Used Canvas: Schritt 7, Bild 1 von 3 How to Restore a Used Canvas: Schritt 7, Bild 2 von 3 How to Restore a Used Canvas: Schritt 7, Bild 3 von 3
    • Grab the wood frame and fold one side of the canvas to its original state.
    • Tightly secure the canvas and firmly set the stapler on the area that needs a staple.
    • With a steady and secure fist, firmly press on the top of the stapler.
    • Continue this process all around the canvas.
  8. How to Restore a Used Canvas: Schritt 8, Bild 1 von 3 How to Restore a Used Canvas: Schritt 8, Bild 2 von 3 How to Restore a Used Canvas: Schritt 8, Bild 3 von 3
    • Tightly fold the corners of the canvas and secure it with a final staple keeping it in place.
Ziellinie
Sandra Henriquez
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S1-G7, Harris Spring 2021 Mitglied von CSU Los Angeles, Team S1-G7, Harris Spring 2021
CSULA-HARRIS-S21S1G7
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 26
Insgesamt: 965
