Einleitung
This guide will demonstrate a technique for repairing damaged threads on skateboard trucks. A stripped axle may seem expensive, as new skate trucks cost about $60, but they can be repaired in under 10 minutes. This method saves time and money.
Was du brauchst
Begin by removing the wheel by removing the old nut with a skate tool.
Insert the axle thread tool into the 1/2" socket on the skate tool.
With the thread tool in the socket, insert the axle into the tool and turn your skate tool clockwise throughout the entire axle. Once you feel you have reached the end of the axle, unscrew the tool.
Inspect your threads for their quality. You should now have even threads with deep grooves. If they appear uneven, you may need to go back and repeat step 4.
Place your wheel back on the axle.
Discard the old wheel nut and replace it with a new one. Tighten the new nut onto the wheel.
Ensure that your new wheel nut is seated correctly on the threads.
Congrats on learning how to repair a stripped axle. Hopefully this guide helped you get back on your wheels!
