Zum Hauptinhalt wechseln
How to Reupholster a Bench Cushion
Was du brauchst
  1. How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: Schritt 1, Bild 1 von 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: Schritt 1, Bild 2 von 3 How to Reupholster a Bench Cushion, How to Reupholster a Bench Cushion: Schritt 1, Bild 3 von 3
    • Remove the base from the frame of the bench.
    • If the base is screwed on the frame, use a screwdriver or a drill to remove the screws.
  2. How to Reupholster a Bench Cushion: Schritt 2, Bild 1 von 3 How to Reupholster a Bench Cushion: Schritt 2, Bild 2 von 3 How to Reupholster a Bench Cushion: Schritt 2, Bild 3 von 3
    • Lift the staples with the flathead screwdriver before going in with the pliers.
  3. How to Reupholster a Bench Cushion: Schritt 3, Bild 1 von 3 How to Reupholster a Bench Cushion: Schritt 3, Bild 2 von 3 How to Reupholster a Bench Cushion: Schritt 3, Bild 3 von 3
    • Use a pair of pliers to grip the staples.
    • Twist and pull the staples to remove them from the bench.
  4. How to Reupholster a Bench Cushion: Schritt 4, Bild 1 von 3 How to Reupholster a Bench Cushion: Schritt 4, Bild 2 von 3 How to Reupholster a Bench Cushion: Schritt 4, Bild 3 von 3
    • Place clean material down so the new fabric does not get dirty.
    • Place the fabric with the design face down on top of the clean sheet.
    • Then place the cushion, then the base face down.
  5. How to Reupholster a Bench Cushion: Schritt 5, Bild 1 von 3 How to Reupholster a Bench Cushion: Schritt 5, Bild 2 von 3 How to Reupholster a Bench Cushion: Schritt 5, Bild 3 von 3
    • Keep the safety lock closed when not using the staple gun.
    • When ready to use the staple gun, pull the safety lock down.
    • Insert the staples into the stapler.
  6. How to Reupholster a Bench Cushion: Schritt 6, Bild 1 von 3 How to Reupholster a Bench Cushion: Schritt 6, Bild 2 von 3 How to Reupholster a Bench Cushion: Schritt 6, Bild 3 von 3
    • Pull the fabric taut and staple every 4 inches.
  7. How to Reupholster a Bench Cushion: Schritt 7, Bild 1 von 3 How to Reupholster a Bench Cushion: Schritt 7, Bild 2 von 3 How to Reupholster a Bench Cushion: Schritt 7, Bild 3 von 3
    • Fold the corners of the fabric inward then on top.
    • Staple the fabric down twice for each corner.
    • Cut the excess fabric along the shorter sides of the base length.
    • Place the base back onto the frame.
    • If any screws were removed, screw them back on.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
CSU Los Angeles, Team 4-4, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 4-4, Briggs Spring 2022
CSULA-BRIGGS-S22S4G4
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 451
