Einleitung
Rewiring a lamp is an easy process. Lamps can be very expensive if not bought at a discount or thrift store. If people are able to rewire their lamps from home, knowing this process would save money to buy an entirely new lamp. Most of these tools to rewire a lamp can be found in the average person's house. However, if they are not readily available available to the person fixing the lamp they will be able to purchase these items at the nearest Lowe's or Home Depot.
Was du brauchst
Loosen the setscrew with the screwdriver so you can unscrew the socket base.
Unscrew the socket base from the threaded tube with your hand.
With your hand, pry the socket shell out of its base.
Remove the socket with your hand and then cut the wires with the wire cutters.
Strip off 1/2" of the insulation with the wire stripper and twist the wire strands together by hand.
By hand, tie an underwriters knot in the cord.
Also by hand, connect the wires by wrapping them clockwise around the screws and tighten and connect the neutral wire to the silver screw.
By hand, pull the excess cord down through the lamp.
Still using your hand, slip the insulation sleeve and socket shell over the socket and snap the shell into the base.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
