Einleitung
Tire rotation ensures even wear on the tires. Front and rear axles support different weights, and will wear differently. Rotating tires allows for even wear on a set of four tires, maximizing the lifespan of the set.
You should rotate your tires every five thousand to ten thousand miles to reduce uneven tire wear.
Was du brauchst
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Once the car is raised, remove the lug nuts with the ratchet attached to a 3/4'' socket.
Remove the tire off the wheel studs and place it aside.
The wheel studs are the metal bolts sticking out of the wheel hub in the center.
On the same side of the vehicle, go to the rear tire.
Using a ratchet attached to a 3/4" socket, loosen wheel lug nuts. Do not remove them.
Place the floor jack under the frame in front of the rear tire.
Raise the jack until the tire is off the ground.
Remove the rear tire. Roll and place the tire onto the wheel studs on the front wheel.
Tighten the lug nuts using your hand until they are tight.
Roll the previous front tire to the rear and repeat the tightening process
Using a torque wrench, tighten the lug nuts on each wheel to the car manufacturer's recommended torque specification found in the user's manual.
Using an air compressor and the air pressure gauge, fill the front and rear tires to appropriate amount.
Follow these steps in the same order to rotate the tires on the other side of the vehicle.
7 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Really useful and valuable content, Thank you.
<a href="https://highwaypakistan.com/">highway trading comapny</a>
