Zum Hauptinhalt wechseln
How to Salt Scour a Cast Iron Skillet
Was du brauchst
  1. How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: Schritt 1, Bild 1 von 3 How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: Schritt 1, Bild 2 von 3 How to Salt Scour a Cast Iron Skillet, How to Salt Scour a Cast Iron Skillet: Schritt 1, Bild 3 von 3
    • Wet the pan in hot water.
  2. How to Salt Scour a Cast Iron Skillet: Schritt 2, Bild 1 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 2, Bild 2 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 2, Bild 3 von 3
    • Apply coarse salt and scrub the pan with a damp dish towel until the pan is stripped of rust and surface particles.
  3. How to Salt Scour a Cast Iron Skillet: Schritt 3, Bild 1 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 3, Bild 2 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 3, Bild 3 von 3
    • Rinse off the pan in cool water and wipe dry with a new towel.
  4. How to Salt Scour a Cast Iron Skillet: Schritt 4, Bild 1 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 4, Bild 2 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 4, Bild 3 von 3
    • Evenly apply the cooking oil spray coat to the pan and wipe away excess oil.
  5. How to Salt Scour a Cast Iron Skillet: Schritt 5, Bild 1 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 5, Bild 2 von 3 How to Salt Scour a Cast Iron Skillet: Schritt 5, Bild 3 von 3
    • Bake-in coating at 450 degrees Fahrenheit for one hour.
  6. How to Salt Scour a Cast Iron Skillet: Schritt 6, Bild 1 von 2 How to Salt Scour a Cast Iron Skillet: Schritt 6, Bild 2 von 2
    • Allow to cool for 20 minutes.
Abschluss
The steps provided in this guide have walked you through the process of salt-scouring and re-seasoning a cast iron pan. Now you are ready to cook using a fresh and clean cast-iron pan.
Repeat steps 4-6 if needed to fill in any gaps in the pan that are still bare.
Ethan
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 233
