Zum Hauptinhalt wechseln
How to Sew a Cloth Seat Cushion Strap
Was du brauchst
  1. How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: Schritt 1, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap, How to Sew a Cloth Seat Cushion Strap: Schritt 1, Bild 2 von 2
    • Find the hole in the seat cushion.
  2. How to Sew a Cloth Seat Cushion Strap: Schritt 2, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap: Schritt 2, Bild 2 von 2
    • Cut a piece of thread long enough to fit the hole.
    • Put the thread through the eye of the needle.
  3. How to Sew a Cloth Seat Cushion Strap: Schritt 3, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap: Schritt 3, Bild 2 von 2
    • Tie a knot at the end of the thread.
  4. How to Sew a Cloth Seat Cushion Strap: Schritt 4, Bild 1 von 1
    • Sandwich the strap in between the two pieces of fabric.
  5. How to Sew a Cloth Seat Cushion Strap: Schritt 5, Bild 1 von 1
    • Push the needle from the inside of the cushion, around where the broken seam is.
  6. How to Sew a Cloth Seat Cushion Strap: Schritt 6, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap: Schritt 6, Bild 2 von 2
    • Use a small stitch over the material.
    • Pull the needle until thread is taut.
  7. How to Sew a Cloth Seat Cushion Strap: Schritt 7, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap: Schritt 7, Bild 2 von 2
    • Use a small stitch under the material.
    • Pull the needle until the thread is taut.
  8. How to Sew a Cloth Seat Cushion Strap: Schritt 8, Bild 1 von 1
    • Continue the same alternating stitch pattern of over and under until the end of the hole.
  9. How to Sew a Cloth Seat Cushion Strap: Schritt 9, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap: Schritt 9, Bild 2 von 2
    • Push the needle in through the end of the sewn hole.
  10. How to Sew a Cloth Seat Cushion Strap: Schritt 10, Bild 1 von 3 How to Sew a Cloth Seat Cushion Strap: Schritt 10, Bild 2 von 3 How to Sew a Cloth Seat Cushion Strap: Schritt 10, Bild 3 von 3
    • Wrap the thread around the needle two times.
    • Tie off your thread with a knot.
  11. How to Sew a Cloth Seat Cushion Strap: Schritt 11, Bild 1 von 1
    • Pull the knot tightly.
  12. How to Sew a Cloth Seat Cushion Strap: Schritt 12, Bild 1 von 3 How to Sew a Cloth Seat Cushion Strap: Schritt 12, Bild 2 von 3 How to Sew a Cloth Seat Cushion Strap: Schritt 12, Bild 3 von 3
    • Push the needle through the side of the cushion.
  13. How to Sew a Cloth Seat Cushion Strap: Schritt 13, Bild 1 von 2 How to Sew a Cloth Seat Cushion Strap: Schritt 13, Bild 2 von 2
    • Pull until taut and cut off the excess thread.
    • This will hide the excess thread.
  14. How to Sew a Cloth Seat Cushion Strap: Schritt 14, Bild 1 von 1
    • Now, your seat cushion is fixed!
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
Deepa Bhat
253 Reputation
1 Anleitung geschrieben
UC Davis, Team 3-5, Whithaus Spring 2024 Mitglied von UC Davis, Team 3-5, Whithaus Spring 2024
UCD-WHITHAUS-S24S3G5
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 35
Insgesamt: 486
