Einleitung
This guide is for anyone who has a purse with a flaw or two. Every situation is not going to be the same, but this guide is specific to the flaws I have with my purse involving a hole in the inside where the fabric is, and 2 zippers that came off. Usually when something is broken, it gets tossed in the trash, and a new item gets purchased. The idea is to keep the purse instead of throwing it away, by fixing it. Everyone wants security and privacy. With this guide I will be serving that purpose. Holes are common and can be fixed by sewing, and zippers can easily be reattached in a short amount of time.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Locate the hole.
    • Locate the hole.
    • It’s important to analyze the area and make sure you have enough thread to cover the area; more is always better.
  2. Get a needle and thread ready to sew and make a knot at the end of the thread.
    • Get a needle and thread ready to sew and make a knot at the end of the thread.
    • Sew the hole together.
    • Notice that the fabric looks smooth and straight, this is from folding the frayed parts of the fabric inward to make the sewing process easier.
    • Make sure to end your sewing session with a secured knot, and cut off excess thread.
    • Use tweezers to grab one side of the opened coil.
    • Locate the detached zipper slider and turn it backwards.
    • This is done while still holding one side of the opened coil.
    • Place one side of the coil inside the zipper slider just a little using tweezers.
    • Grab the other side of the opened coils and place that side inside the zipper slider.
    • Make sure that each of the coils are placed evenly inside the slider.
    • Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
    • Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
Abschluss
ReNieka Perry
Mitglied seit 21.01.2018
169 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2018
USFSM-STEWART-S18S1G1
15 Mitglieder
14 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 86
