Einleitung
This guide is for anyone who has a purse with a flaw or two. Every situation is not going to be the same, but this guide is specific to the flaws I have with my purse involving a hole in the inside where the fabric is, and 2 zippers that came off. Usually when something is broken, it gets tossed in the trash, and a new item gets purchased. The idea is to keep the purse instead of throwing it away, by fixing it. Everyone wants security and privacy. With this guide I will be serving that purpose. Holes are common and can be fixed by sewing, and zippers can easily be reattached in a short amount of time.
Was du brauchst
Sew the hole together.
Make sure to end your sewing session with a secured knot, and cut off excess thread.
Use tweezers to grab one side of the opened coil.
Place one side of the coil inside the zipper slider just a little using tweezers.
Grab the other side of the opened coils and place that side inside the zipper slider.
Once both coils are even, using the zipper “Pull”, slowly slide the “Pull” closing it.
Repeat steps 4 to 9 for the other zipper wrapping up the coil process and being able to close both zippers.
2 weitere Personen haben diese Anleitung absolviert.
