Zum Hauptinhalt wechseln
How to Sew a Hole in a Sock
Was du brauchst
  1. How to Sew a Hole in a Sock, How to Sew a Hole in a Sock: Schritt 1, Bild 1 von 1
    • Cut about 15 inches of thread in a similar color to your sock.
  2. How to Sew a Hole in a Sock: Schritt 2, Bild 1 von 3 How to Sew a Hole in a Sock: Schritt 2, Bild 2 von 3 How to Sew a Hole in a Sock: Schritt 2, Bild 3 von 3
    • Pass the thread through the needle’s hole and knot it at the end.
  3. How to Sew a Hole in a Sock: Schritt 3, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 3, Bild 2 von 2
    • Turn the sock inside-out.
    • Flatten the sock.
  4. How to Sew a Hole in a Sock: Schritt 4, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 4, Bild 2 von 2
    • Starting at one corner of the hole, insert the needle through the edge and pull it out the other edge.
  5. How to Sew a Hole in a Sock: Schritt 5, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 5, Bild 2 von 2
    • Repeat Step 4, but now in the opposite direction not too far from the previous stitch.
  6. How to Sew a Hole in a Sock: Schritt 6, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 6, Bild 2 von 2
    • Continue repeating Steps 4 and 5 until you get to the end of the hole.
  7. How to Sew a Hole in a Sock: Schritt 7, Bild 1 von 1
    • Insert half of the needle and wrap the thread around the needle three times.
  8. How to Sew a Hole in a Sock: Schritt 8, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 8, Bild 2 von 2
    • While holding the thread, send the needle all the way through.
  9. How to Sew a Hole in a Sock: Schritt 9, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 9, Bild 2 von 2
    • Repeat Steps 8 and 9 one last time.
  10. How to Sew a Hole in a Sock: Schritt 10, Bild 1 von 2 How to Sew a Hole in a Sock: Schritt 10, Bild 2 von 2
    • Cut the excess thread with the scissors.
  11. How to Sew a Hole in a Sock: Schritt 11, Bild 1 von 1
    • Turn the sock so the right side is facing outwards.
Ziellinie
Alan Figueroa
193 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 53
Insgesamt: 2,689
