Einleitung
A hole in a sock can be reason to throw it out, but fixing the problem before it gets worse can save your favorite pair. This technique can save you from throwing out a perfectly good, repairable sock with a hole in it. It may be helpful to practice sewing before attempting this method, although this is a great place to start your sewing journey.
Was du brauchst
Cut about 15 inches of thread in a similar color to your sock.
Starting at one corner of the hole, insert the needle through the edge and pull it out the other edge.
Repeat Step 4, but now in the opposite direction not too far from the previous stitch.
