Einleitung
Use this guide to create an invisible stitch in a torn jeans.
An invisible stitch is a hidden stitch for sewing the edges in a torn fabric. This technique can be used on most materials but this guide will be focusing on jeans. Sewing an invisible stitch is quite easy to do and does not need any special skills. The stitch is almost fully invisible and creates a professional looking finished stitch to the jeans. To successfully create an invisible stitch, follow the instructions below.
Was du brauchst
Insert the thread through the needle and knot the end of the thread.
Insert the needle to the opposite side of the tear creating a horizontal line with the thread.
Pull out the needle from the inside of the jeans.
Then move the needle to the opposite end of the tear.
Repeat these steps of creating horizontal lines with the thread until you reach the end of the tear.
Pull the thread from the inside until the horizontal lines of stitching are completely invisible.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
