Zum Hauptinhalt wechseln
How to Sharpen Troy-Bilt TB110 Lawnmower Blades
Was du brauchst
  1. How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 1, Bild 1 von 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades, How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 1, Bild 2 von 2
    • Disconnect the spark plug wire.
    • This step is critical to avoid an accidental startup since we are working on the blade.
  2. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 2, Bild 1 von 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 2, Bild 2 von 2
    • Put saran wrap on the inside of the gas cap.
    • This is done to prevent gas from spilling out when we turn over the lawnmower.
  3. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 3, Bild 1 von 1
    • Turn the lawn mower over on its side.
  4. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 4, Bild 1 von 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 4, Bild 2 von 2
    • Use a 5/8 ratchet or wrench to remove the bolt. Then remove the blade.
    • Note how the blade is oriented on the lawn mower for reassembly.
    • Do not grab it from the sharp parts of the blade.
  5. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 5, Bild 1 von 1
    • Clean the blade with a scraper or a wire brush to remove grass residue .
  6. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 6, Bild 1 von 1
    • Secure the blade in a vice.
  7. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 7, Bild 1 von 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 7, Bild 2 von 2
    • Sharpen the blade with a file or with a grinder. Follow the angle that is already established and move the file along until the edge becomes sharp.
    • Be carful when checking for sharpness. You can very gently run your finger along the edge to check.
    • The blade does not need to be as sharp as a razor blade. Try to make it as sharp as pair of scissors. Check the lawnmower for specific details.
  8. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 8, Bild 1 von 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 8, Bild 2 von 2
    • Put the blade back onto the lawn mower and screw the bolt back on while safely securing the blade.
    • Again be careful not to hold the blade by the sharp edges.
  9. How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 9, Bild 1 von 2 How to Sharpen Troy-Bilt TB110 Lawnmower Blades: Schritt 9, Bild 2 von 2
    • Flip the lawn mower back to the upright position and remove the saran wrap from the gas cap.
    • Plug the spark plug wire in until you hear a click.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrew DePari
193 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G7, O'Connell Spring 2021 Mitglied von UMass Dartmouth, Team S1-G7, O'Connell Spring 2021
UMASSD-O'CONNELL-S21S1G7
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 64
Insgesamt: 1,163
