Zum Hauptinhalt wechseln
How to Shorten Pant Legs With a Sewing Machine
Was du brauchst
  1. How to Shorten Pant Legs With a Sewing Machine, How to Shorten Pant Legs With a Sewing Machine: Schritt 1, Bild 1 von 1
    • Flip the pairs of pants inside out.
    • The seam lines should be visible, markings the inside of the pants will allow for an easier clean up.
    • Place your pants on a flat surface and flatten the pant leg.
  2. How to Shorten Pant Legs With a Sewing Machine: Schritt 2, Bild 1 von 1
    • Measure the width of the pant leg using a ruler or measuring tape.
    • Mark your fitting size on the pants using tailoring chalk.
  3. How to Shorten Pant Legs With a Sewing Machine: Schritt 3, Bild 1 von 2 How to Shorten Pant Legs With a Sewing Machine: Schritt 3, Bild 2 von 2
    • Use a seam ripper to unseam the hem of your pants a little bit past your fitting line.
    • Make another marking from your fitting line, leaving half an inch of space in between the two.
    • In this case, the top line is our fit line and the bottom line is our cut line.
  4. How to Shorten Pant Legs With a Sewing Machine: Schritt 4, Bild 1 von 3 How to Shorten Pant Legs With a Sewing Machine: Schritt 4, Bild 2 von 3 How to Shorten Pant Legs With a Sewing Machine: Schritt 4, Bild 3 von 3
    • Use a comma ruler to extend both of your markings up the length of the pants.
    • Cut along the lower line.
  5. How to Shorten Pant Legs With a Sewing Machine: Schritt 5, Bild 1 von 3 How to Shorten Pant Legs With a Sewing Machine: Schritt 5, Bild 2 von 3 How to Shorten Pant Legs With a Sewing Machine: Schritt 5, Bild 3 von 3
    • Sew your new seam along thefitting line.
    • As you get closer to the original seam, blend your new seam into the original.
    • Sewing machines can easily cause injuries, use caution when operating and go slow.
  6. How to Shorten Pant Legs With a Sewing Machine: Schritt 6, Bild 1 von 2 How to Shorten Pant Legs With a Sewing Machine: Schritt 6, Bild 2 von 2
    • Once you've laid your new seam, refold the hem and place a seam to hold it.
    • Make sure to go slow, the thickness of the cloth can make this difficult.
    • Repeat the procedure for the other pant leg.
Ziellinie
Divyansh Bhatti
134 Reputation
1 Anleitung geschrieben
York University, Team B-4, Woodhouse Fall 2023 Mitglied von York University, Team B-4, Woodhouse Fall 2023
YORK-WOODHOUSE-F23SBG4
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 128
